Amount of storage allocated for Jira OnDemand 6.3
Helmuth Santos July 14, 2014
1. What is the amount of storage allocated for JIRA OnDemand 6.3?
2. Is the alloted storage per user or per level of users (i.e. 25 users, 50 users)?
3. If we are nearing the limit of storage what can we do? What are the options?
MJ
July 14, 2014
All information regarding OnDemand storage can be found here. There is no relation between the user tier and the maximum storage size of your instance. The current storage limit is set to 25GB, which is pretty hard to achieve. Ordinarily attachments are the major factor when it comes to storage. Unless you get contacted by Atlassian direclty related to your total storage, I would not worry too much about it.
Hi Mick. Thanks for your response. It's very helpful. Much appreciated!
MJ
July 15, 2014
Glad to be of help. If you could upvote and/or accept the answer, this will increase visibility for other users in case they are looking for the same answers as you.
