An issue moved to another project still remains in the original Agile board
Raye Raskin
June 28, 2013
Is this as designed? Is there a workaround? What is the proper procedure when doing this?
Raye Raskin
July 15, 2013
This is a known issue and basically a duplicate of https://jira.atlassian.com/browse/GHS-6541.
Justin Alex Paramanandan
June 30, 2013
If this moved issue is still showing in the Agile board, you might need to reindex the instance to rebuild the search cache. If this doesn't work, try the following:
  1. Shutdown JIRA.
  2. Delete the following directory:
    • $JIRA_HOME/caches/indexes
  3. Restart JIRA.
  4. Run the reindexing again.
