Apache2 proxy problem
Azure
April 21, 2016
Hi
I have problems with my apache2 proxy. The dashbaord and issue of project can not correctly loaded. Rest is ok (projects, users, admin mode...)
My configuration:
HTTPS <==> Proxy <==> HTTP <==> Tomcat
&lt;VirtualHost _default_:443&gt;
    ProxyRequests Off
    ProxyPreserveHost On
    &lt;Proxy *&gt;
        Require all granted
    &lt;/Proxy&gt;
    ProxyPass           /    http://localhost:8080/
    ProxyPassReverse /    http://localhost:8080/
    &lt;Location /&gt;
        Require all granted
    &lt;/Location&gt;
&lt;/VirtualHost&gt;
Server.xml
&lt;Connector acceptCount="100" connectionTimeout="20000" disableUploadTimeout="true" enableLookups="false" maxHttpHeaderSize="8192"
        maxThreads="150" minSpareThreads="25" port="8080" protocol="HTTP/1.1" redirectPort="8443" useBodyEncodingForURI="true"
        proxyName="jira.tem.ch" proxyPort="443" scheme="https" secure="true" /&gt;
Any ideas?
Peter
Azure
April 24, 2016
I solved. It was a firewall issue.
Thx, Peter
Jonas Andersson
April 21, 2016
This is not a complete solution, but might help you get where you need to be.
I would replace the localhost in the ProxyPass and Reverse, with the real hostname of the box.
Additionally, when setting up application links it might help you to bypass the proxy. So leave the proxy in place for external visitors, but in the application links you set http://hostname.bla.bla:8080/
