Appfire Jira CLI : how can i move issue another project?
I want to clone issue to another project. so i run below. but i got a error message.
i think schema is different.
can you explain additional option?
>> --action cloneIssue --issue "OEMUNIFUP-331659" --link Cloners --toProject "PBN_HM907"
Remote error: customfield_14204 (VCRM 반영): VCRM 반영 is required.
Hi @김영수
as per the provided action and error message, it shows there is a mandatory field on the target project
in your case to clone the issue to project "PBN_HM907" please mention the value of the mandatory field.
as an example, here is the command that I used with the mandatory field (check box) on the target project
jirac --action cloneIssue --issue COM-3 --toProject CM --field "Ture or False" --value True
If you have any further questions you can post a comment on the following support ticket we will be happy to assist you.
https://appfire.atlassian.net/browse/SUPPORT-126414
BR,
K Vivek Rao
Appfire.
Hi @김영수 and welcome to the community!
I'm Luka from codefortynine and if you have trouble getting your issues cloned, you could also try our Deep Clone for Jira app.
