Assign duedate value to Label using automation
Vinutha GR December 13, 2023
When an issue is transitioned to Done status.
Then Edit Label field
I am trying to set the due date as {{issue.duedate}}
Its throwing an error as below
Additional fields contains invalid field(s) in 'update' or 'fields' section : Custom Field Name
"fields":{
"customfield_10023":{"value":"test"},
"lables":{{issue.duedate}}
Even the customfield is giving an error saying the it shoudl be string
Fazila Ashraf
Hi @Vinutha GR
Can you share the json part where you set this?
Not sure what you are asking for.
Under automation after when
in Then Edit issues and under additional fields i have the above snippet.
Bill Sheboy
December 13, 2023
Hi @Vinutha GR
Adding to the answer from @Fazila Ashraf
Your rule has both a typo in the field name and the incorrect syntax to add a label with JSON.  Please look here to learn how to add a label with JSON:
https://support.atlassian.com/cloud-automation/docs/advanced-field-editing-using-json/#Labels
Like Fazila Ashraf likes this
Thanks Bill, I was able to resolve this.
Like Bill Sheboy likes this
