Assign issues in work mode
sarah Thompson
January 23, 2014
I find it very difficult to easily assign issues to my different users. It looks like I should be able to drag and drop my issues to different users in work mode if I order the swimlanes by Assignee but this doesn't appear to work. What am I doing wrong? Also, is there a way to change assignee in plan mode on the detail screen? Right now I have to go to the ... menu and Assign, I'd like to make the Assignee field ediable on the detail screen.
Henning Tietgens
January 26, 2014
A fast way is to hit "a" and enter the assignee if the issue is selected.
Andy Nguyen
January 25, 2014
Hi Sarah,
The use of Swimlanes is to serve display purpose only. Drag & Drop is based on columns for progress tracking purpose hence you cannot change Assignee by doing so. However, I think you're reasonable about an option for changing Assignee from the Issue Detail View pane in Plan (and Work) mode. If you insist on this, I can help to raise a feature request for it in our forum.
Andy
