×Hi all,
I have been using a Python script someone else wrote for me, to import Trello cards into Jira.
I love that script, but there is a small update I'd like to do, and that is: Assigning all imported card to myself in Jira.
I have being trying different things an reading other questions and solutions, but I can't figure it out. (I am not a dev myself).
Above is part of my code. The assignee row is the 1 row I've added, and since the code is broken. So I think I've done something wrong.
(I've hidden part of my user ID, because I don't know if this is sensitive information)
The code:
+ ', "assignee":{"id": {557058:3911cfb9-4331-4994-8713-XXXXXXXXXXXX}'"}'
Can someone tell me what I am doing wrong here, please?
Thank you!
Edit: The card created, is always "created by" me.
I guess this is because the "auth" uses my email address?
Maybe that helps.
Hello @[deleted] ,
I might not be the best person to answer this question since I don't know python that much, but looking at the line added by you I can see that:
"assignee": {"accountId": "557058:70a51490-9608-499e-93a9-xxxxxxxxx"}
Can you kindly try to change it as below and see if it works:
+ ', "assignee":{"accountId": "557058:3911cfb9-4331-4994-8713-XXXXXXXXXXXX"}'
Also, yes, the issues are created by you since you use your account to authenticate the REST API calls.
Finally, for the future, please notice that this is not the best place to get help on development related questions. The right resources are listed in https://developer.atlassian.com/resources.
Specifically:
I hope this helps.
Dario
"I might not be the best person to answer this question"
Well, I think you are. Because it worked.
Thanks!
You are very welcome @[deleted] !
I am happy to know it worked :)
