I'm having a problem that I'm sure is just some sort of setup issue. My assignee field won't display on the appropriate screen.
Pertinent info:
Any help would be appreciated here. I'm under the gun to get this set up properly and can't seem to figure this out.
Thanks a ton in advance,
Steve
If your login doesn't have Assign permissions for that Project, the Assignee field won't display. Check your Project Roles & Permissions.
*sigh*
I knew it was going to be something simple. I guess it's better to exercise a little humility rather than bang your head against your desk.
Thanks for your help, csytsma. That was exactly the issue.
Oh, I've been there many times. Usually it's the customfield Contexts that get me.
Check the Field Configuration for the Project/Issue Type, to make sure it isn't Hidden.
