Hi - Is there any way to link skills and stages in portfolio to a component? By default, all stages created appears to distribute story points (at story level) across the stages equally. If stages are created at a level which aligns with, in my case, a specific OS, then the skills being added will only be required for say an android story and an android stage/skill. As it is the only way around this is to re-assign all stories story points individually to a skill or stage?
Hi Adam,
Currently no, you cannot link skills and stages to components, but please add a vote to the following feature request to add this function into portfolio:
Also if you have any additional feedback on the functionality please drop a comment detailing your use case per the Implementation of New Features Policy to help out.
Earl
