what are the correct setup steps for connecting with the on demand service using Google authentication when trying to access JIRA via Atlassian Connector for IntelliJ IDEA?
Currently I get authentication failed when not using HTTP authentication. If I also enter the google credentials on HTTP Authentication I get a 401 (Unauthorized).
com.atlassian.theplugin.commons.remoteapi.RemoteApiException: (401)Unauthorized
at com.atlassian.connector.commons.jira.soap.JIRASessionImpl.login(JIRASessionImpl.java:199)
at com.atlassian.connector.commons.jira.JIRAServerFacade2Impl.testServerConnection(JIRAServerFacade2Impl.java:140)
at com.atlassian.theplugin.commons.jira.IntelliJJiraServerFacade.testServerConnection(IntelliJJiraServerFacade.java:243)
at com.atlassian.theplugin.idea.config.serverconfig.ProductConnector.connect(ProductConnector.java:31)
at com.atlassian.theplugin.ConnectionWrapper.run(ConnectionWrapper.java:63)
Hi Francisco,
I am using IDEA 11.1.1 successfully with my Google integrated OnDemand instance.
Ensure "Accept remote API calls" is ON, under administratio -> Issues -> General Configuration.
username should be your username in OnDemand, you can find it in your user profile, mine does NOT my full email address.
password is a password within OnDemand, in my case it is not the same as my Google account.
I use my base server URL http://iaraddev.jira.com
Let me know if this helps, if not, I can mess around some more.
See attached screenshots.
This does not work for me, we can't reset our password because Google is integrated:
How did you get this to work?
I also am having this issue, has anyone figured out how to fix it?
Glad that worked out. I recall spending a few frustrating hours before I had it working succesfully myself ;o) How are you enjoying PHPStorm? I have heard good things about it.
- Stuart
I'm loving PHPStorm since January.
It has many features that other IDE's unfortunatelly don't have which make my daily tasks much more efficient and smooth, specially when programming for Web.
They've just released version 4 and there are so many improvements from v3 that really makes me think it was a good investment. :)
They've just released version 5 and it is amazing!
Hi Stuart
thanks a lot for your message! It was really helpful and I got it working.
Basically I had to change two things:
Just to be clear though, I'm not using IDEA but PHPStorm 3.0.3 with plugin version 3.0.4.
Cheers!
Francisco
