Atlassian Plugin Sdk won't start Jira behind firewall
Gernot Eger April 6, 2014
I am trying to start Jira 6.0.5 from behind a firewall, with access to the internet solely through proxies. However, jira won't start with: [ERROR] BUILD ERROR [INFO] ------------------------------------------------------------------------ [INFO] Unable to execute mojo Embedded error: java.net.ConnectException: Connection timed out: connect The same project starts perfectly while running an a machine outside the corporate newtork. However, now I have to investigate some effects of proxy Settings, so I have to work inside teh corporate network. I attached a build ouput (atlas-debug -X), as well as my pom.xml thanks in advance Gernot
Gernot Eger April 13, 2014
Resolution: I made a mistake in my proxy activation configuration. Utilizing
atlas-mvn help:effective-settings
I found out I wasn't actually using the proxy.
Boris Georgiev [Appfire]
April 7, 2014
The attached files are not visible.
To make this work you have to put proper proxy settings in your maven settings.xml
https://maven.apache.org/guides/mini/guide-proxies.html
