Atlassian jira log and atlassian jira incoming mail log is not getting updated
Leena Bakshi
Hi All,
I am getting the following error in the jira log and it hasnt been updated since 1:55 am on 10/23/2017
 This is when we had a database failover ( planned activity) and database came up:
2017-10-22 09:27:00,528 QuartzScheduler_atlassian-scheduler-quartz1.clustered-NON_CLUSTERED_MisfireHandler ERROR      [NoModule] There was an error getting a DBCP datasource.
java.lang.RuntimeException: Unable to obtain a connection from the underlying connection pool
                at org.ofbiz.core.entity.jdbc.interceptors.connection.ConnectionTracker.trackConnection(ConnectionTracker.java:60)
                at org.ofbiz.core.entity.transaction.DBCPConnectionFactory.trackConnection(DBCPConnectionFactory.java:243)
                at org.ofbiz.core.entity.transaction.DBCPConnectionFactory.getConnection(DBCPConnectionFactory.java:74)
                at org.ofbiz.core.entity.ConnectionFactory.tryGenericConnectionSources(ConnectionFactory.java:69)
                at org.ofbiz.core.entity.transaction.JNDIFactory.getConnection(JNDIFactory.java:146)
                at org.ofbiz.core.entity.TransactionFactory.getConnection(TransactionFactory.java:136)
                at org.ofbiz.core.entity.ConnectionFactory.getConnection(ConnectionFactory.java:59)
                at org.ofbiz.core.entity.ConnectionFactory$1.getConnection(ConnectionFactory.java:52)
                at org.ofbiz.core.entity.jdbc.DatabaseUtil.getConnection(DatabaseUtil.java:133)
                at com.atlassian.jira.scheduler.Quartz1ConnectionProvider.getConnection(Quartz1ConnectionProvider.java:30)
                at org.quartz.utils.DBConnectionManager.getConnection(DBConnectionManager.java:109)
                at org.quartz.impl.jdbcjobstore.JobStoreSupport.getConnection(JobStoreSupport.java:712)
                at org.quartz.impl.jdbcjobstore.JobStoreTX.getNonManagedTXConnection(JobStoreTX.java:69)
                at org.quartz.impl.jdbcjobstore.JobStoreSupport.doRecoverMisfires(JobStoreSupport.java:3132)
                at org.quartz.impl.jdbcjobstore.JobStoreSupport$MisfireHandler.manage(JobStoreSupport.java:3923)
                at org.quartz.impl.jdbcjobstore.JobStoreSupport$MisfireHandler.run(JobStoreSupport.java:3943)
Caused by: java.sql.SQLException: Network error IOException: Connection refused: connect
                at net.sourceforge.jtds.jdbc.JtdsConnection.<init>(JtdsConnection.java:436)
                at net.sourceforge.jtds.jdbc.Driver.connect(Driver.java:184)
                at org.apache.commons.dbcp.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:38)
                at org.apache.commons.dbcp.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:582)
                at org.apache.commons.pool.impl.GenericObjectPool.borrowObject(GenericObjectPool.java:1148)
                at org.apache.commons.dbcp.PoolingDataSource.getConnection(PoolingDataSource.java:106)
                at org.apache.commons.dbcp.BasicDataSource.getConnection(BasicDataSource.java:1044)
                at org.ofbiz.core.entity.transaction.DBCPConnectionFactory$1.call(DBCPConnectionFactory.java:247)
                at org.ofbiz.core.entity.transaction.DBCPConnectionFactory$1.call(DBCPConnectionFactory.java:244)
                at org.ofbiz.core.entity.jdbc.interceptors.connection.ConnectionTracker.trackConnection(ConnectionTracker.java:54)
                ... 15 more
Caused by: java.net.ConnectException: Connection refused: connect
                at java.net.DualStackPlainSocketImpl.connect0(Native Method)
                at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:79)
                at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:345)
                at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
                at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
                at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
                at java.net.Socket.connect(Socket.java:589)
                at net.sourceforge.jtds.jdbc.SharedSocket.createSocketForJDBC3(SharedSocket.java:288)
                at net.sourceforge.jtds.jdbc.SharedSocket.<init>(SharedSocket.java:251)
                at net.sourceforge.jtds.jdbc.JtdsConnection.<init>(JtdsConnection.java:331)
                ... 25 more
Leena Bakshi
We got this problem because a night before database server was rebooted due to some other project and since our jira db sits on a physical clustered db env, a failover happened and to fix this issue we needed to reboot Jira server. After that jira started functioning as expected.
Leena Bakshi
I had to reboot the Application server and ran reindexing after that and Everything worked fine after that.
Leena Bakshi
2017-10-23 01:55:51,440 http-bio-443-exec-129 ERROR user.name115x23053x1 1g57grk 172.18.236.68 /browse/DCP-2094 [NoModule] There was an error getting a DBCP datasource.
at org.ofbiz.core.entity.jdbc.SQLProcessor.getConnection(SQLProcessor.java:395)
at org.ofbiz.core.entity.jdbc.SQLProcessor.prepareStatement(SQLProcessor.java:544)
at org.ofbiz.core.entity.GenericDAO.createEntityListIterator(GenericDAO.java:960)
at org.ofbiz.core.entity.GenericDAO.selectListIteratorByCondition(GenericDAO.java:883)
at org.ofbiz.core.entity.GenericDAO.selectByAnd(GenericDAO.java:730)
at org.ofbiz.core.entity.GenericHelperDAO.findByAnd(GenericHelperDAO.java:150)
at org.ofbiz.core.entity.GenericDelegator.findByAnd(GenericDelegator.java:901)
at org.ofbiz.core.entity.GenericDelegator.findByAnd(GenericDelegator.java:879)
at org.ofbiz.core.entity.GenericDelegator.findByAnd(GenericDelegator.java:848)
at com.atlassian.jira.ofbiz.DefaultOfBizDelegator.findByAnd(DefaultOfBizDelegator.java:97)
at com.atlassian.jira.ofbiz.WrappingOfBizDelegator.findByAnd(WrappingOfBizDelegator.java:76)
at com.atlassian.jira.issue.managers.DefaultIssueManager$IssueFinder.getIssueFromIssueEntityByProjectAndNumber(DefaultIssueManager.java:1251)
at com.atlassian.jira.issue.managers.DefaultIssueManager$IssueFinder.getIssueFromIssueEntity(DefaultIssueManager.java:1246)
at com.atlassian.jira.issue.managers.DefaultIssueManager$IssueFinder.getIssue(DefaultIssueManager.java:1216)
at com.atlassian.jira.issue.managers.DefaultIssueManager.getIssue(DefaultIssueManager.java:156)
at com.atlassian.jira.issue.managers.DefaultIssueManager.getIssueObject(DefaultIssueManager.java:436)
at com.atlassian.jira.bc.issue.DefaultIssueService.getIssue(DefaultIssueService.java:141)
at com.atlassian.jira.bc.issue.DefaultIssueService.getIssue(DefaultIssueService.java:134) <+2> (DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:497)
at com.atlassian.plugin.osgi.hostcomponents.impl.DefaultComponentRegistrar$ContextClassLoaderSettingInvocationHandler.invoke(DefaultComponentRegistrar.java:134)
at com.sun.proxy.$Proxy231.getIssue(Unknown Source) <+2> (DelegatingMethodAccessorImpl.java:43)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:307)
at org.springframework.osgi.service.importer.support.internal.aop.ServiceInvoker.doInvoke(ServiceInvoker.java:58)
at org.springframework.osgi.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:62)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:131)
at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:119)
at org.springframework.osgi.service.util.internal.aop.ServiceTCCLInterceptor.invokeUnprivileged(ServiceTCCLInterceptor.java:56)
at org.springframework.osgi.service.util.internal.aop.ServiceTCCLInterceptor.invoke(ServiceTCCLInterceptor.java:39)
at org.springframework.osgi.service.importer.support.LocalBundleContextAdvice.invoke(LocalBundleContextAdvice.java:59)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
at com.sun.proxy.$Proxy4506.getIssue(Unknown Source)
at com.atlassian.jira.plugin.issuenav.IssueNavAction.getRequestedIssue(IssueNavAction.java:608)
at com.atlassian.jira.plugin.issuenav.IssueNavAction.handleRedirectsForIssueNav(IssueNavAction.java:281)
at com.atlassian.jira.plugin.issuenav.IssueNavAction.doDefault(IssueNavAction.java:242) <+2> (DelegatingMethodAccessorImpl.java:43)
at webwork.util.InjectionUtils$DefaultInjectionImpl.invoke(InjectionUtils.java:70)
at webwork.util.InjectionUtils.invoke(InjectionUtils.java:56) <+2> (ActionSupport.java:438) (ActionSupport.java:157)
at com.atlassian.jira.action.JiraActionSupport.execute(JiraActionSupport.java:88) <+7> (DefaultInterceptorChain.java:39) (NestedInterceptorChain.java:31) (ChainedInterceptor.java:16) (DefaultInterceptorChain.java:35) (GenericDispatcher.java:225) (GenericDispatcher.java:154) (JiraWebworkActionDispatcher.java:152)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727) <+2> (ApplicationFilterChain.java:303) (ApplicationFilterChain.java:208)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52) <+11> (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (XContentTypeOptionsNoSniffFilter.java:22) (AbstractHttpFilter.java:31) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (HeaderSanitisingFilter.java:44) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (IteratingFilterChain.java:46) (DelegatingPluginFilter.java:70)
at com.atlassian.jira.onboarding.postsetup.ui.PostSetupAnnouncementsFilter.doFilter(PostSetupAnnouncementsFilter.java:61) <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
at com.atlassian.jira.tzdetect.IncludeResourcesFilter.doFilter(IncludeResourcesFilter.java:40) <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
at com.atlassian.jira.baseurl.IncludeResourcesFilter.doFilter(IncludeResourcesFilter.java:38) <+8> (AbstractHttpFilter.java:31) (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70) (ContextFilter.java:25) (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
at com.atlassian.servicedesk.internal.web.RedirectExternalCustomerToPortalFilter.doFilter(RedirectExternalCustomerToPortalFilter.scala:18) <+4> (AbstractHttpFilter.java:31) (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
at com.atlassian.prettyurls.filter.PrettyUrlsCommonFilter.preventDoubleInvocation(PrettyUrlsCommonFilter.java:38)
at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFixupFilter.doFilter(PrettyUrlsSiteMeshFixupFilter.java:24) <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
at com.atlassian.prettyurls.filter.PrettyUrlsDispatcherFilter.doFilter(PrettyUrlsDispatcherFilter.java:60) <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFilter.doFilter(PrettyUrlsSiteMeshFilter.java:74) <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
at com.atlassian.prettyurls.filter.PrettyUrlsMatcherFilter.doFilter(PrettyUrlsMatcherFilter.java:56) <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
at com.atlassian.labs.botkiller.BotKillerFilter.doFilter(BotKillerFilter.java:30) <+11> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (ServletFilterModuleContainerFilter.java:77) (ServletFilterModuleContainerFilter.java:63) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (PageBuilderFilter.java:69) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (IteratingFilterChain.java:46) (DelegatingPluginFilter.java:70)
at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) <+19> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (ServletFilterModuleContainerFilter.java:77) (ServletFilterModuleContainerFilter.java:63) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (SecurityFilter.java:85) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (BaseLoginFilter.java:172) (JiraLoginFilter.java:70) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (IteratingFilterChain.java:46) (DelegatingPluginFilter.java:70) (OAuthFilter.java:79) (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) <+8> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (ServletFilterModuleContainerFilter.java:77) (ServletFilterModuleContainerFilter.java:63) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (IteratingFilterChain.java:46) (DelegatingPluginFilter.java:70)
at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) <+12> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (ServletFilterModuleContainerFilter.java:77) (ServletFilterModuleContainerFilter.java:63) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (ApplicationDispatcher.java:748) (ApplicationDispatcher.java:486) (ApplicationDispatcher.java:411) (ApplicationDispatcher.java:338) (DelegatingMethodAccessorImpl.java:43)
at net.bull.javamelody.JspWrapper.invoke(JspWrapper.java:150)
at net.bull.javamelody.JdbcWrapper$DelegatingInvocationHandler.invoke(JdbcWrapper.java:286)
at com.sun.proxy.$Proxy5330.forward(Unknown Source)
at com.atlassian.jira.plugin.issuenav.IssueNavRewriteFilter.doFilter(IssueNavRewriteFilter.java:97) <+4> (AbstractHttpFilter.java:31) (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFixupFilter.doFilter(PrettyUrlsSiteMeshFixupFilter.java:36) <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFilter.doFilter(PrettyUrlsSiteMeshFilter.java:92) <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
at com.atlassian.labs.botkiller.BotKillerFilter.doFilter(BotKillerFilter.java:36) <+26> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (ServletFilterModuleContainerFilter.java:77) (ServletFilterModuleContainerFilter.java:63) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (AccessLogFilter.java:105) (AccessLogFilter.java:89) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (XsrfTokenAdditionRequestFilter.java:54) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (SiteMeshFilter.java:181) (SiteMeshFilter.java:85) (SitemeshPageFilter.java:124) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (PageBuilderFilter.java:90) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (CommittedResponseHtmlErrorRecoveryFilter.java:63) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (IteratingFilterChain.java:46) (DelegatingPluginFilter.java:70)
at com.atlassian.jira.mobile.servlet.filter.MobileRedirectFilter.doFilter(MobileRedirectFilter.java:59) <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
at com.atlassian.jira.mobile.servlet.filter.DesktopSwitchFilter.doFilter(DesktopSwitchFilter.java:46) <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
at com.atlassian.jira.mobile.servlet.filter.MobileAuthenticationFilter.doFilter(MobileAuthenticationFilter.java:92) <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) <+22> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (ServletFilterModuleContainerFilter.java:77) (ServletFilterModuleContainerFilter.java:63) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (SecurityFilter.java:239) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (TrustedApplicationsFilter.java:100) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (BaseLoginFilter.java:172) (JiraLoginFilter.java:70) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (IteratingFilterChain.java:46) (DelegatingPluginFilter.java:70) (OAuthFilter.java:79) (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) <+13> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (ServletFilterModuleContainerFilter.java:77) (ServletFilterModuleContainerFilter.java:63) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (ProfilingFilter.java:99) (JIRAProfilingFilter.java:19) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (AbstractJohnsonFilter.java:71) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208)
at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92) <+5> (UrlRewriteFilter.java:394) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (IteratingFilterChain.java:46) (DelegatingPluginFilter.java:70)
at com.atlassian.analytics.client.filter.JiraAnalyticsFilter.doFilter(JiraAnalyticsFilter.java:40)
at com.atlassian.analytics.client.filter.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:32) <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) <+3> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (DelegatingPluginFilter.java:70)
at net.bull.javamelody.MonitoringFilter.doFilter(MonitoringFilter.java:200)
at net.bull.javamelody.MonitoringFilter.doFilter(MonitoringFilter.java:178)
at net.bull.javamelody.PluginMonitoringFilter.doFilter(PluginMonitoringFilter.java:85)
at net.bull.javamelody.JiraMonitoringFilter.doFilter(JiraMonitoringFilter.java:104) <+45> (DelegatingPluginFilter.java:78) (IteratingFilterChain.java:42) (ServletFilterModuleContainerFilter.java:77) (ServletFilterModuleContainerFilter.java:63) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (ChainedFilterStepRunner.java:87) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (AbstractCachingFilter.java:33) (AbstractHttpFilter.java:31) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (AbstractEncodingFilter.java:41) (AbstractHttpFilter.java:31) (PathMatchingEncodingFilter.java:49) (AbstractHttpFilter.java:31) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (JiraStartupChecklistFilter.java:79) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (MultipartBoundaryCheckFilter.java:41) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (ChainedFilterStepRunner.java:87) (JiraFirstFilter.java:61) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (GzipFilter.java:121) (GzipFilter.java:92) (JiraGzipFilter.java:56) (ApplicationFilterChain.java:241) (ApplicationFilterChain.java:208) (StandardWrapperValve.java:220) (StandardContextValve.java:122) (AuthenticatorBase.java:610) (StandardHostValve.java:171) (ErrorReportValve.java:103) (StandardEngineValve.java:116) (AccessLogValve.java:950) (CoyoteAdapter.java:408) (AbstractHttp11Processor.java:1070) (AbstractProtocol.java:611) (JIoEndpoint.java:316)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
