Atlassian sdk compatability for Jira 9.4.6
Singa Selva Sankar
We are in the process of upgrading our Jira data center from 8.20.14 to 9.4.6 and we have some custom plugins that are compiled using atlassian-sdk 8.2.7 which seems to be the latest,
Would like to know what is the compatible sdk version for Jira 9.4.6. I don't see the compatibility listed in the sdk version documentation.
Any help here is much appreciated.
Sachin Dhamale
@Singa Selva Sankar,
Any latest SDK will be compatible to the jira version 9.4.6.
Sachin
Singa Selva Sankar
@Sachin Dhamale I see the latest sdk version is 8.2.7 and in the documentation is not showing the supported Jira version. screenshot for your reference.
Sachin Dhamale
HI Singa,
even tough its not showing over their but the plugin should work.
there is not too much difference in the API
try to create a one dummy plugin with that sdk and check the version
Like Sanjen Bariki likes this
Singa Selva Sankar
@Sachin Dhamale thanks, let me check.
