I am attempting to piece together how I can use the JIRA CLI with an API token instead of a password.
The example provided in the documentation is this
java -jar `dirname $0`/lib/jira-cli-7.8.0.jar --server https://my.example.com --user automation --password "automation" "$@
I've attempted to modify it to match curl examples provided [here](https://community.atlassian.com/t5/Jira-questions/How-do-I-get-an-authorization-API/qaq-p/818421) and on the API tokens documentation ([here](https://confluence.atlassian.com/cloud/api-tokens-938839638.html))
java -jar `dirname $0`/lib/jira-cli-7.8.0.jar --server https://my.example.com --user me@example.com:myprovidedtoken "$@
However, this doesn't work. When I run
./jira.sh --action getServerInfo --outputFormat 2
I get:
This function requires a non-blank value for parameter password.
Moving the token to the password parameter doesn't work either:
java -jar `dirname $0`/lib/jira-cli-7.8.0.jar --server https://my.example.com --user me@example.com --password "myprovidedtoken" "$@
Then rerunning:
Remote error: User is not authorized to perform the request. Response code: 401.
I am an admin and should have fun access.
Question: How do I properly pass an API token to the jira CLI?
Bonus, in case I missed a permission: How do I grant a user access to utilize the API?
Can you please confirm your CLI version? The support for Access Token is available from CLI 7.7 . See the last comment on the ticket :
https://bobswift.atlassian.net/browse/ACLI-191
If your version is correct then you should be able to provide token in the password value.
Below is the documentation for this :
https://bobswift.atlassian.net/wiki/spaces/ACLI/pages/392757809/Authentication
Regards
Prakhar
Hi @Prakhar Srivastav {Appfire}, I had been using CLI7.8, but moved to the snapshot 7.9 this morning. That seems to be working.
Hi @Andy Wegner
It should work with CLI 7.8 also. If it is not , can you please raise a bug here .
Regards
Prakhar
