Is there a way to auto add a comment to the parent issue based on the transition of a subtask issue?
It is possible to do so by using a post-function from a third-party plugin to run a scripted post-function to add the comment. These are the steps needed to use this:
I hope this helps!
Best regards,
Matheus Fernandes
Hey matheus,
It something similar also possible for JIRA OnDemand users ?
We are looking forward to do the same - add a coment to the parent issue on sub-task resolve - but the "copy field value to parent issue" post funtion is not able to copy a comment so we started to look for a "workaround" but this is the only one I found so far - and installing scripts and adding files does not sound to mu ch of a solid answer for OnDemand users.
I do not know if this is possible in OnDemand due to the restrictions in the platform as you mentioned. My suggestion would be to transform your comment here in a question here in Answers, so that anyone else would be able to see.
Jelly scripts could possibly do that I think, but again I'm not sure if it works in OnDemand.
