Auto comment JQL Query for 2w old status?
Lauris Sestulis
May 18, 2015
Hi.
I need to make JQL query to find issues in status for 14 days (2w) and make a auto comment. I have two options but they don't work as I need.
This one finds issues and comments but at the same time checks issue updates and that leads leads to postponed comments.
project = PROJ AND status in ("Waiting For Customer") AND type in ("Change Request") and updated < -14d
This option finds issues don't check the updates of issues but makes auto comment every day.
project = PROJ AND status in ("Waiting For Customer") AND type in ("Change Request") not status changed after -2w
I need that only one reminder comment be added 2 weeks after status is changed to Waiting on customer and is still in that status after 2 weeks. Any other updates should not be taken into consideration.
Udo Brand
May 19, 2015
If you have scriptrunner installed you could use in addition the 'commented' jql function
project = PROJ AND status in ("Waiting For Customer") AND type in ("Change Request") not status changed after -2w and not issuefunction in commented("after-2w")
So you would only find issue that haven't changed their status in the last 2 weeks and have not been commented in that period as well (you can refine the commented subquery like "after -2w by <USER>"
For details see: https://jamieechlin.atlassian.net/wiki/display/GRV/Scripted+JQL+Functions#ScriptedJQLFunctions-commented(commentquery)
Lauris Sestulis
May 22, 2015
THX this worked for me smile
