Auto create a ticket in another project
Becky Muffler
March 29, 2018
I am trying to create a ticket in Project B when a ticket in Project A is created.   I have tested the post function on a workflow step and it works when I ask it to create a ticket within the same project, but when I change the function to create the ticket in Project B instead of Project A, the post function does not execute.  Is there a limitation or barrier I am not aware of?  I am using the Jira Misc Workflow Extensions plugin to create the post function (JMWE).
3 votes
David Fischer
There is no such limitation. However, it might be caused by a missing value for a required field, or by a permission issue. You need to check your logfile (atlassian-jira.log), or activate the "Make transitions fail when an error occurs in a JMWE post-function" option on the JMWE Configuration admin page to see the error on the transition screen.
Becky Muffler
March 29, 2018
That was it!  Thanks David!
David Fischer
@Becky Muffler can you please  "accept" my reply (click on the checkmark button)?
Ryan Kearney
March 29, 2018
