Automate Load Project Configuration
Roshan Surana July 14, 2016
I'm automating the load project configuration task in project configuration plugin.
For that i'm using below two command lines
curl -u admin:admin --cookie-jar cookies.txt "http://localhost:8080/secure/Dashboard.jspa" --head
curl -b cookies.txt "http://localhost:8080/secure/project-config-file-upload.jspa" -F "projectConfigFile=@C:\config-dump.xml" -F "applyChanges=true"
Both commands don't throw any error but load configuration is not happening. Can you please suggest what is wrong in above command lines.
I'm referring
https://awnaba.atlassian.net/wiki/display/PCP/How+to+automate+export+and+load+of+project+configurations
José Marañón [Awnaba Software S.L.]
August 16, 2016
This question was managed and solved as issue PCP-449 in our tracker. Please see the answer there.
Cheers!
Steven F Behnke
July 15, 2016
You still didn't label your question so I did for you.
Project Configuration add-on
Steven F Behnke
July 14, 2016
What add-on? You didn't label your question with the plugin so you're not going to get vendor-specific help.
