Automated Issue Comment using Groovy Script
Jeremy Outlaw
October 30, 2024
Good Afternoon
I am hoping someone is able to provide some insight as to why the following script does not work. I am attempting to use custom script to have comments placed on an issue dependent on a custom field value.
I am using the following script but I am not having any luck:
import com.atlassian.jira.issue.comments.CommentManager
// Get the issue object
issue = issue.getIssueType("TWU - Wires")
// Get the custom field value
def customField = customFieldManager.getCustomFieldObject("TWU - Call Back")
def customFieldValue = issue.getCustomFieldValue("TWU - Call Back")
// Define the comment manager
CommentManager commentManager = ComponentAccessor.getCommentManager()
// Add a comment based on the custom field value
if (customFieldValue == "Call back completed using two step verification") {
    commentManager.create(issue, issue.reporter, "Call back completed using two step verification", true)
} else if (customFieldValue == "Call back completed - Client is ineligible for two step verification - Client has no SSN on file") {
    commentManager.create(issue, issue.reporter, "Call back completed - Client is ineligible for two step verification - Client has no SSN on file", true)}
    else if (customFieldValue == "Call back completed - Client is ineligible for two step verification - Client's contact info does not validate via Innovis") {
    commentManager.create(issue, issue.reporter, "Call back completed - Client is ineligible for two step verification - Client's contact info does not validate via Innovis", true)}
    else if (customFieldValue == "Call back completed - Client is ineligible for two step verification - Wire authorized agent is not account signer, no SSN on file") {
    commentManager.create(issue, issue.reporter, "Call back completed - Client is ineligible for two step verification - Wire authorized agent is not account signer, no SSN on file", true)}
    else if (customFieldValue == "Call back completed for Consumer International Wire using two step verification") {
    commentManager.create(issue, issue.reporter, "Call back completed for Consumer International Wire using two step verification", true)}
    else if (customFieldValue == "Call back completed for Consumer International Wire - Client is ineligible for two step verification - Client has no SSN on file") {
    commentManager.create(issue, issue.reporter, "Call back completed for Consumer International Wire - Client is ineligible for two step verification - Client has no SSN on file", true)}
    else if (customFieldValue == "Call back completed for Consumer International Wire - Client is ineligible for two step verification - Client's contact info does not validate via Innovis") {
    commentManager.create(issue, issue.reporter, "Call back completed for Consumer International Wire - Client is ineligible for two step verification - Client's contact info does not validate via Innovis", true)}
    else if (customFieldValue == "Call back completed for Consumer International Wire - Client is ineligible for two step verification - Wire authorized agent is not account signer, no SSN on file") {
    commentManager.create(issue, issue.reporter, "Call back completed for Consumer International Wire - Client is ineligible for two step verification - Wire authorized agent is not account signer, no SSN on file ", true)
} else if (customFieldValue == "Call back is not required per Call Back Internal Matrix") {
    commentManager.create(issue, issue.reporter, "Call back waived per Matrix.", true)
Doreen Undiri
October 31, 2024
Hi  @Jeremy Outlaw ,
Am not so good with groovy script so I asked one of my friend to help check your script,  and this was his output
  • The line issue = issue.getIssueType("TWU - Wires") is likely causing a problem. issue.getIssueType("TWU - Wires") is not a valid method to get an issue object,  if you’re running this script within a workflow transition or an event listener, issue should already represent the current issue, so no need to reassign it.
  • You need to use the custom field object to retrieve its value from the issue. Currently, issue.getCustomFieldValue("TWU - Call Back") is incorrect. Instead: def customFieldValue = issue.getCustomFieldValue(customField)
He revised the codes,
def customField = customFieldManager.getCustomFieldObjectByName("TWU - Call Back")
} else if (customFieldValue == "Call back completed - Client is ineligible for two step verification - Client's contact info does not validate via Innovis") {
} else if (customFieldValue == "Call back completed - Client is ineligible for two step verification - Wire authorized agent is not account signer, no SSN on file") {
} else if (customFieldValue == "Call back completed for Consumer International Wire using two step verification") {
} else if (customFieldValue == "Call back completed for Consumer International Wire - Client is ineligible for two step verification - Client has no SSN on file") {
} else if (customFieldValue == "Call back completed for Consumer International Wire - Client is ineligible for two step verification - Client's contact info does not validate via Innovis") {
} else if (customFieldValue == "Call back completed for Consumer International Wire - Client is ineligible for two step verification - Wire authorized agent is not account signer, no SSN on file") {
Goodluck I hope it helped
Dd
FREE
