×So using <... auto="True"> in one of my transitions (as documented in What is your most valuable Jira "trick"), I am conditionally (based on SOX field) firing an Auto-Approve transition after users manually do a Verify transition.
Unfortunately, when I add a Comment during the Verify transition, I end up with a duplicate of the initial comment added during Verify. Here's the portion of the workflow I'm working on:
image2015-9-16 20:19:26.png
I suspect that because Auto-Approve still has "Add a comment to an issue if one is entered during a transition." post-function, it somehow thinks the Verify Comment is something it needs to add to the issue, and I end up with it there twice.
Any ideas? Thanks all!
Ah, as is often the case after asking for help, I figured it out.
Since I'm hacking workflow XML anyways, why not try removing the "Add a comment" post-function there:
<function type="class"> <arg name="class.name">com.atlassian.jira.workflow.function.misc.CreateCommentFunction</arg> </function>
Hey, that worked. Nice.
