Automatic creation of components when a project is created newly
rbalamu2
We have same set of components (~30) to be manually created everytime when a new project is created. Is there an option available to create components automatically during project creation? kindly help!
3 accepted
Fabio Racobaldo _Herzum_
Hi @rbalamu2 ,
unfortunately, using builtin features, you can't do that. There is an open request in order to make components sharable per pmultiple projects https://jira.atlassian.com/browse/JRACLOUD-8663
As a workaround, you can use https://marketplace.atlassian.com/apps/6398/jira-command-line-interface-cli?tab=overview&hosting=cloud features. In particular, you could use copyComponents to do that https://bobswift.atlassian.net/wiki/spaces/JCLI/pages/1059396661/copyComponents
Hope this helps,
Fabio
rbalamu2
Hi @Fabio Racobaldo _Herzum_ ,
That's a quick reply. Thanks for sharing :)
you're welcome @rbalamu2
Marlene Kegel - codefortynine
Hi @rbalamu2,
I am Marlene from codefortynine.
If you're working with company-managed projects, you can also try our app Deep Clone for Jira.
With our app you can clone entire company-managed projects, along with issues, components and versions.
Karyna Tyrnavska _SaaSJet
Hi, @rbalamu2
Another solution, you can check if you're comfortable with Marketplace plugins, is Business Process Manager. My team has created it to deal with recurring business processes and standardize them.
You can create your custom template of the process with
  • various steps = Jira issues
  • create a custom dynamic form in the steps
  • set up an approval process with conditions
  • add project, issue type and assignee(s) so BPM could automatically create Jira issue
To figure out how Business Process Manager can optimize your processes, book the demo with our product manager
rbalamu2
Thanks @Karyna Tyrnavska _SaaSJet . Let me check.
~Rahini
