A large number (50+) projects have been set up, but only a few of the issues in each project were estimated. I would like to apply a label at the Task/Story level to mark the issues without estimates. However, some Tasks/Stories have subtasks with estimates, if that is the case the label isn't needed.
Thoughts?
Edit: To clarify this is focused on time estimates not story point estimates.
Here is what I did:
If: all match
Else-if: all match
Hi Jeremy,
Do you know the name of the field that stores the time estimates?
If so, you should be able to create a JQL query and then do a Bulk change to update the issues.
Thanks John. I created an automation that runs weekly on selected projects.
