Automation - Copy Single Issue Picker value to child tickets
AbrahamA
March 26, 2022
Hello
I need to copy value of single issue picker from triggering issue to child tickets. I could copy values of some fields from parent to child, but not issue picker. Can you please help me.
Here is what I have done so far:
Ste Wright
Hi @AbrahamA
Testing this, this worked...
"fields": {
"customfield_10123":"{{triggerissue.High Profile Issue.key}}"
^ Just replace 10123 with High Profile Issue's custom field ID.
Ste
AbrahamA
March 27, 2022
Hi Stephen
Thanks for the reply.
I have tried and it did not work.
Here is how it looks on trigger issue screen( I have made sure the field is visible on available on child issue view screen)
Ste Wright
Hi @AbrahamA
Did it cause an error? If so, what was it?
Ste
AbrahamA
March 27, 2022
Hi Stephen
I did not see any errors on the screen.
AbrahamA
March 27, 2022
The field 'High Profile Issue' does not have value for issue XYZ-538 and will not be displayed on the view issue page. Set value for that field so that it shows up.
Ste Wright
Hi @AbrahamA
Is that the audit log error in the last comment?
Could you send a screenshot of your most recent rule, and an audit log entry from when you tried to activate the rule?
I tried this in our instance and it worked as required, so it should be possible to make it work in yours!
AbrahamA
March 28, 2022
Hi Stephen
Thanks for your help, I got it to work.
For anyone facing similar issue, the fields should be in value changes. I had two fields with almost similar names and got mixed up,.
But since I am listening on description tickets from all projects are getting matched and appear in Audit log, wish project name could be matched first (is there a way)?
I am accepting answer as it solved my initial question.
Like Ste Wright likes this
AbrahamA
March 28, 2022
In the audit log I do not see any rules failing for the tickets which belong to vrt. All are from different projects.
