Hi All!
I'm facing a problem that i can't figure out - details:
I use an automation rule to copy a few custom field data from Epic fields to its Isseu fields. It is seems working, but in case of a few issues i have got the following error in the audit log, and also found that Jira did't make the necessary copies:
Hi @Gábor Hajdu
For a question like this, please post images of your complete rule, showing the details of the trigger and actions, and of the audit log details showing the rule execution. Those will provide context for the community to offer ideas. Thanks!
Until we see those...that symptom could happen when:
After we see your rule information, we can narrow down the cause of this symptom.
Hi @Bill Sheboy , thank you for your kindly answer.
My rule is the following:
And the result:
Both the issue and its epic are exists and in active state - that is why i can't understand the error result. For example:
Epic: BPSZH-861 > Issue(Task): BPSZH-862
Thanks for that information.
The audit log also shows BPSZH-860 was picked up by the scheduled trigger: what type of issue is that?
I suspect is it not an epic and it does not have a parent epic, as that would cause the errors in the Edit Issue action.
If your intention is the second part of the rule only runs for issues which have an epic parent, you can enforce that by adding another condition test after the test "Issue Type is not one of: Epic".
Thanks for your suggestions.
BPSZH-860 is another active issue (task) that has an active parent epic BPSZH-854. There is no different with BPSZH-861/BPSZH-862.
Again, i've double checked:
- Only Issue/Tasks are used (sub-tasks doesn't)
- All the issues are active issues, and has an active parent epic.
- Only a few of them ends up with error described earlier.
- Using the issue editor, i can click to the linked epics and open them with no problem.
- Only the rule automation seems like can't find the right epic. (but only 5% of the issues)
Also as an evidence i created a filter, that demonstrates that JIRA finds the issue and its epic also:
The Epic Name is the same the issues "Parent". I wonder is it possible to make a query based on unique IDs not names to be sure that the issue-epic connection is correct.
That is puzzling...Let's try to narrow this down a bit.
Are you using a Company-managed or a Team-managed project? You can find that information at the bottom-left of the page on the expanding area.
You note this only happens to about 5% of the issues. Can you reproduce this symptom consistently?
Now let's get more data! After your condition Issue Type is not an Epic, please add an action to write this to the audit log:
START issue:{{issue.key}}; parent:{{issue.parent}}; epic link:{{issue.Epic link}} END;
Then try to recreate the symptom and post what you see in the audit log.
All of the projects are Company-managed business projects.
Reproducing: for the affected issues - yes. For that ones, if i make some modification on the issue in order to be selected by automation on its next run, consistently got the error.
Log result: "[...] START issue:BPSZH-862; parent:BPSZH-861; epic link: END; [...]"
Issue and parent data is correct. Epic link is empty.
When that log entry occurred, did the error you saw also happen?
If not, please try to reproduce the condition so we get both the error and the log entry, and then post an image showing the complete audit log details for that rule run. Thanks!
I confirm, i reproduced the same error on the same issue+epic.
I've tried with more log fields:
"START issue:{{issue.key}}; parent:{{issue.parent}}; epic link:{{issue.Epic link}}; issue parent epic link:{{issue.parent.Epic Link}}; issue parent key:{{issue.parent.key}}; END;"
The result the same:
I just noticed something you posted earlier:
My understanding is business projects are all team-managed, not company-managed. Do you see "company-managed" indicated at the lower-left side of the page?
If it is team-managed, I believe this epic symptom is a known problem, that has become intermittent since the epic link field started sunsetting.
I can suggest a work-around or you (and your site admin) can follow-up with the Atlassian Support team to learn what they suggest.
The work-around is to use advanced edit with JSON for those fields, rather than use the field selection from the drop-down list. Then use the parent (epic) field's custom field id values instead of the field name. This would bypass the problem team-managed projects have with epics in rules.
All of the projects are Company-managed:
if i understand you, the workaround you suggested is only for team-managed projects.
Thanks for that information, as when I check business projects they appear as Team-managed (TMP).
That work-around I suggested helps whenever a rule cannot resolve the fields, or they are not listed in the drop-down fields. The TMP defect/symptom is just one example. So it might help or not.
At this point, I suggest working with your Jira site admin to contact Atlassian support here: https://support.atlassian.com/contact/#/ If you are on a paid license your admin can submit support tickets.
They may see something in their logging that we are missing. When you hear back from them, please post what you learn to benefit the community.
Thanks Bill for your efforts! Sure, I'll loop back here any outcome i'll get from the support.
Hi @Bill Sheboy , i think i solved the problem.
I 've changed the edit action by replacing the "...from Epic issue" options to "...from Parent issue".
With this all of the issues were updated fine!
Is there any chance that the issues that are having problems are Sub-tasks?
From the description, your logic seems fine, but if Jira for some reason was unable to make the copy looking at a Copy from Epic reference, it means that perhaps the issue is not associated with an Epic or it is a Sub-task.
Can you check this and if it is not the case, can you put here the example of the JQL you are using in Scheduled?
Thanks @Fernando Eugênio da Silva for your answer!
I've double checked, and all of my errors got on normal tasks, not sub-tasks.
Both the Task and its Epic are exists and in active state.
I have attached images in my previous answer to Bill Sheboy. May you can take a look at them, if i am missed something necessary.
Thanks!
I'm finding that "copy from Epic issue" doesn't work reliably anymore — probably a symptom of Atlassian's retiring of Epic Link in favor of Parent Link.
Instead, you'll have to do something along the lines of these smart values, especially necessary for Sub-tasks trying to pull from Epics grandparents:
Tasks: {{issue.parent.key}}
Sub-tasks: {{issue.parent.epic.key}}
