Automation : Copy resolution
Mario GELES
May 15, 2023
Hi Community,
I have made an automation to close the linked issues of the trigger issue when this one is closed.
I want the linked issues have the same resolution than the trigger issue. So I used the set issue action, I selected the resolution field and the "Copy" option.
But it doesn't work.
This is the error log :
Modifier le ticket
Erreur lors de la modification de tickets
SI-2005 (Spécifiez la Resolution (id or name) au format de chaîne (resolution)), SI-2006 (Spécifiez la Resolution (id or name) au format de chaîne (resolution))
Could someone help me please ? :)
2 accepted
4 votes
JM Perrot
Hello @Mario GELES
It's possible to watch your rule ?
And you need to specify from where you want to copy your resolution (typically if you are in a branch you need to specify from the trigger issue)
Mario GELES
May 15, 2023
Ho thank you very much @JM Perrot
I didn't see that there was a dropdown box hide on the "copy Resolution from" button.
Well to be exact I didn't see that was a button.
I feel a little bit silly right now
Thank you very much for your help
Have a great day :)
Like JM Perrot likes this
Shivaprasad Hattaraki
Hello Mario,
Use Edit Issue action and select Resolution field.
choose copy from trigger issue.
Screenshot 2023-05-15 163206.pngRegards,
Shivaprasad
Mario GELES
May 15, 2023
Hi @Shivaprasad Hattaraki thank you for your help too !
As I said I didn't see that "Copy Resolution" was a button.
So I set "from trigger issue" instead of "Actual issue" and that's good my rule works !
Have a great day :)
