Automation: How to extract a specific text from description
CI January 10, 2024
The issue Description is like the one in the example below.
I'd like to extract only Text2 from Device.
Which expression can I use?
Description :
Date
Text1
Device
Text2
Text3
Location
Text4
Text5
Text6
I tried substringBetween(Device,Location) but it captures both Text2 and Text3. I want only Text2. Is there any way to capture the line after Device
Alexis Robert
Hi @Creative Ideas ,
I would try using a different expression to extract Text2 from your example. Can you try this :
{{issue.Description.substringAfter("Device").trim()}}
Let me know if this helps,
--Alexis
CI January 10, 2024
Hi @Alexis Robert  - Thanks for your support. But it captures all the text after Device.
Below is the output.
Bill Sheboy
January 10, 2024
Hi @Creative Ideas -- Welcome to the Atlassian Community!
Adding to Alexis's answer...
Your description appears to contain newlines (line feeds) and so building on the earlier suggestion, the result could be split() and then grab the first result.
For example:
{{issue.description.substringAfter("Device").split("\n").get(0).trim()}}
To learn more about these text and list functions, please review this documentation:
This may also be possible to do in one step with the match() function, using a regular expression.
Like # people like this
CI January 10, 2024
@Bill Sheboy @Alexis Robert  - Below script worked. Thank you!
If possible can you please share the script with match() function.
