JIRA Automation is in use
how to reflect in the rule the link "blocks" between the issues on the different branche
It is unclear from your screen capture what you are trying to do, other than access information/issues in two different branches. Would you please explain further?
There is no branch nesting with the automation currently.
How many results do you expect to meet these conditions: 1 or many? If it is one, please consider storing the target issue's key somewhere (maybe a custom field), do a re-fetch, and then use the stored key to proceed.
Best regards,
