Automation JIRA
Janvi Kapoor July 17, 2023
When a certain task is completed, you want to see which tasks instead of the link and send that 'task description/name ' in Slack
Right now, we receive the link in Slack
We don't know which task this is
Janvi Kapoor July 18, 2023
Hi, Sure
PFA Automation Workflow, I basically want to send a notification to the team of 'which task' is 'done' and I want them to receive the 'task description' so I am not sure which 'message' to add in the last automation rule of 'send slack messages' and also this automation does not seem to be working
Hope anyone can help me with this
Thank youScreenshot 2023-07-18 at 8.32.38 PM.pngScreenshot 2023-07-18 at 8.32.51 PM.pngScreenshot 2023-07-18 at 8.32.56 PM.pngScreenshot 2023-07-18 at 8.33.00 PM.png
Bill Sheboy
July 18, 2023
Your rule is triggered on issue transition.  But you are branching on created issues...and none are created.
If you truly want to send that notification to Slack for each issue moved to done, please try this instead:
  • trigger: issue transitioned to Done
  • condition: issue type is Task
  • action: send your Slack message, and instead use the fields in {{issue}}, such as {{issue.key}} and {{issue.summary}}  There will be only one issue with that trigger.
Also I noted your text in the Slack message: "Hey team - we've got the following issues left in this sprint".  That seems unrelated to your rule, so what are you wanting to achieve with this rule?
Bill Sheboy
July 17, 2023
Hi @Janvi Kapoor -- Welcome to the Atlassian Community!
I am unclear what you are asking...Are you describing the link to Slack is missing information about the issue, such as the Summary?
Please post images of your complete rule, showing the details of the actions, and of the audit log details showing the rule execution.  Those will provide context for the community to offer suggestions.  Thanks!
FREE
