Automation Plugin - Issue Event Trigger doesn't work?
Agnes Kollin
August 10, 2016
I'm trying the Automation Plugin (2.0.1) for Jira Server (7.1.7).
But no comments or labels are added to resolved issues. Am I doing something wrong?
image2016-8-10 14:10:24.png
gmann August 10, 2016
Do you see any errors in the automation log? For example I have one that runs on a workflow and you can see it in the Event log for automation:
image2016-8-10 14:6:5.png
There is an error column over to the right. If there is no entry, it would suggest your workflow isnt calling it, so check in your test issue and see which workflow its using.
