×When I transition an issue with multiple fix versions to a specific state I'd like to release each version in fix versions. If fix versions contains one version I can do this. However, when the issue has more than one I can't figure out how to do this.
Hi @chad zibbel
without guarantee I found
{{issue.fixVersions.first.name.asJsonString}}
could be working from: https://support.atlassian.com/jira-core-cloud/docs/smart-values-json-functions/
However, please carefully check if it works. I am unsure if this works, the specific smart value always looks for the first version.
On a greater picture it seems the background are lists, here are some examples listed:
https://support.atlassian.com/jira-software-cloud/docs/smart-values-lists/
Happy to hear what the result was!
Daniel
Sure. The automation flow is basically as follows.
The problem is if an issue has more than one version listed in the fix versions field the automation fails because it can't find the version. I suspect this is because it is finding more than one version in that field.
My desire is to split the fix versions field into each distinct version listed and release that version.
Below is a screenshot of my current automation that works when fix versions only contains one version.
