How can I create an Automation Rule for the below scenario.
The project has Epics and tasks within it.
Is there a way an Automation Rule can be set where Trigger is one of the task in an EPIC and the action required is on another task in the same EPIC.
Hi @Munir Patel ,
Yes its possible, please have a look at below screenshot. What its doing is
When is task is transition, it will check the executed task epic link and then get all tasks with same epic link and then transition them to done status. You can add further parameters like sequence number .
Thank you Ramzan, It worked well. Appreciate your time and efforts.
Hi Munir - you should be able to. Can you give an exact example?
Hi John, thanks for your quick response
The scenario is:
Whenever any TaskA is completed and transitioned to Status Done in EPIC1
then I want to check another TaskB in backlog in the same EPIC1 which has a "Task sequence#" as 1 and move it to status "Assigned".
Hi John,
below is the automation rule. Need to make it within the same EPIC of the task in the trigger
