×Hi community. I'm working with several automation, and i need to resolve following casuistic.
Projects
Create Issue and Transitioned from To Process to Done
Automation 1. When the issue is in Done status, automation clone issue in Project 2
This work OK, and link original issues to clone issue.
But We need resolve that if the user transitioned from Done to Cancelled in project 1, the clone Issue of Project 2 update status to Cancelled
Could you guide how can made that last automation?
Thanks in advance!
Best regards!
Alejandra Martìn
What is the scope of your rule (in the details at the top): single-project, multiple-project, or global?
A single-project, scope rule can create (or clone) into other projects, but it cannot see or update them otherwise. And so your rule to sync the cancelled work items will need multiple-project or global scope.
Please discuss this with your Jira Site Admin as they will need to change the scope, and they may want to understand the scenario to prevent any side-effects for other projects.
Please post an image of the audit log details showing the rule execution, expanding the areas at the right side. This will help compare to the rule image for which steps and work items processed.
Hi Bill, thanks for your update. I think rule is not triggered because, audit log not show rule execution, only setup changes.
Thanks in advance!
Based on that image, your rule is stored in a single project and so is not multiple project scope. That may explain why it is not triggering.
Please show the rule details to confirm this.
Hi Bill, I upload rule completly, as you see is for both projects
Thanks, and the next thing to check...
How is the work item transitioned: by a person, by another rule, or some external app / process?
Good Morning Bill. Person performs transition from / to . I was reviewing statuses but those are ok.
Alejandra
Hi Bill, BritHi Bill, Britta. I was trying and trying but finally I got it! It works,
Thanks for your help and your ideas
Alejandra
An alternative to Automation (easier and quicker) to clone issues and then keep their statuses in sync would be to try our app Elements Copy & Sync.
You'll be able to implement your use case within a single configuration rule.
Don't hesitate to check the documentation or even directly try the app (it's free during 30 days and it stays free under 10 users).
Hi Brita, thanks for your answer. I made the rule but seems to be not work. This is the cloend issued in Project. 2 In Linked Work items refer the original work item of project 1. PRoject 1 is cancelled.
Automation is active for those 2 projects, ant not show error
Hi, @Alejandra Martin! 👋
You could solve that using the following steps:
Hope this helps! ✨
