aim is to copy field value of a field from epic to all child issues linked to the epic.
Iam successfull with the first automation, when uers creating the child straight from the epic with this:
The problem now is, that users also creating childs and link them later to the epic. I need to have the same field on the child issue edited when the linking is happening. This is logic for me, but not working, any ideas?
Welcome to the community.
I expect you are using the parent field for this, correct?
This is not related to the Issue Link Parent - Child.
Example rule:
Hi @Harold Pinther-- Welcome to the Atlassian Community!
Adding to Marc's suggestions...
There are several cases to address for a field sync scenario. The level of accuracy you want for the field (and when you want it) may determine the need for additional rules. Those others include at least:
And depending upon how the field is used in the parent, there may be additional rules required.
That worked! Thank you very much Marc.
