I am thinking of a workaround, because we don't have subscriptions to reports.
I would like to get every week a image with the report -burndown chart.
In order to do this I would like to make a script in python that:
- will connect to jira.
- will access to the link of the report
- will make a screenshot of the image (relative xpath)
- will save the photo
- send the photo by email.
- schedule every week.
This script is a little bit complicated.
I can't find the solution for this script, i tried selenium(i think is the best solution).
Please advise, or if someone have a similar script i will be glad.
Thanks in advance.
I will mention i am an administrator of jira.
Best Regards,
David.
Hi @David Pleşu
Instead of using headless browser to take a screenshot why not using Jira REST API, pull the data, dump it somewhere and build your own report?
I would just use Google App Script or Excel VBA to pull the data from Jira and build a report. Other options include using something like Power BI.
Jira reports are basic, if you are spending time building something complicated then I think it would be good to just build own reports.
Ravi
