Automation for Jira Connection connect advanced compare conditions with OR
Jeanette Seewald January 24, 2023
Hi everybody,
I'm setting up an automation for Jira rule and i would need to have several advanced compare if- conditions connected with an OR (to avoid to have a lot of if-else conditions with the same action).
To be more specific: I do have several release names, on which I would like to send an email notification.
If i saw correctly, for the Cloud-Version there should be the possibility at the if-else-block to select "execute actions if at least one of the conditions matches", but I couldn't find it in our latest data center version. (?)
Is there any workaround to do that without the need to have x if-else conditions with the same action implemented?
Thank you a lot in advance,
Jeanette
Samuel Gatica (ServiceRocket)
Hi @Jeanette Seewald
I do see the option available on my automation
What version of Jira and Automation do you have?
Best regards
Sam
Hi @Sam  ,
I do see the If/else block, but I'm missing the option to not have ALL conditions required to be fullfilled, but only ONE condition required (an OR connection):
In the thread I saw that they are using Jira Cloud and I was looking for the same option in the data center version.
We are using the automation for Jira version 8.1.1.
Best regards,
Jeanette
