Automation for Jira Server: Problem with IF conditional statements
Jira Administrators November 5, 2022
I have a custom field called "p-card: missing receipts".  It's a long text field and its ID is 29301.
I want automation to send an email.  If there is a value in that custom field, I want "hello" displayed in the email, otherwise nothing.
I have tried the following but they either display nothing when there is a value in the custom field, or they throw an error:
{{if(not(customfield_29301.isEmpty)),"hello")}}
{{if(p-card: missing receipts,"hello")}}
{{if(customfield_29301)}}hello{{/}}
I used the following documentation: https://support.atlassian.com/cloud-automation/docs/jira-smart-values-conditional-logic/
Jira Administrators November 8, 2022
Sebastian -
Thank you.
1. After much experimenting, I determined the problem: a single-line conditional statement must begin with #if, not if.  This statement works:
    {{#if(not(issue.customfield_29301.isEmpty))}}hello{{/}}
Remove the # and this statement throws an error:
    {{if(not(issue.customfield_29301.isEmpty))}}hello{{/}}
It would appear that this documentation is incorrect: https://support.atlassian.com/cloud-automation/docs/jira-smart-values-conditional-logic/
2.  My experiments indicate that "issue." has no effect in this situation.  All of these worked fine:
  • {{#if(not(customfield_29301.isEmpty))}}hello{{/}}
  • {{#if(not(issue.customfield_29301.isEmpty))}}hello{{/}}
  • {{#if(not(P-card: missing receipts))}}mega hello{{/}}
  • {{#if(not(issue.P-card: missing receipts))}}mega hello{{/}}
Thanks again
Lionel
Sebastian Krzewiński
Thanks Lionel for and explanation!
Hi @Jira Administrators
You should use:
- issue.customfield_29301 instead of customfield_29301
- issue.p-card: missing receipts
Please check this doc - https://support.atlassian.com/cloud-automation/docs/jira-smart-values-issues/#Available-properties.1
Seba
SERVER
