I'm trying to trigger an automation rule (to create a new task), based in Automation for JIRA app when the field: "Parent Link" is updated
Creating a new rule:
The field: "Parent Link" is not available:
Other fields are ok:
Can you help? How can I have the trigger when "Parent Link" field is updated?
Parent Link field is not searchable field so you can't do this like you described.
I don't know what version of Automation for JIRA you have but please check branch rules feature - https://docs.automationforjira.com/getting-started/related-issues.html
Seba
Hi, I have the same question and the above link does not seem to work. Also, since the trigger must be the 1st event, I don't entirely understand what branching rules has to do with the solution.
Is this 'Parent Link' the link between 'Initiatives' and 'Epics' as per the Portfolio add on?
Phil
Yeah Portfolio has since been changed to "advanced roadmaps for Jira" but the hierarchy is
Initiative
