Automation for Jira - create a trigger for "parent link" field edition
Humberto
I'm trying to trigger an automation rule (to create a new task), based in Automation for JIRA app when the field: "Parent Link" is updated
Creating a new rule:
The field: "Parent Link" is not available:ScreenHunter_7094 Jun. 04 08.26.jpg
Other fields are ok:
Can you help? How can I have the trigger when "Parent Link" field is updated?
Sebastian Krzewiński
Hi @Humberto Test user1
Parent Link field is not searchable field so you can't do this like you described.
I don't know what version of Automation for JIRA you have but please check branch rules feature - https://docs.automationforjira.com/getting-started/related-issues.html
Seba
Sven Moon
October 21, 2020
Hi, I have the same question and the above link does not seem to work. Also, since the trigger must be the 1st event, I don't entirely understand what branching rules has to do with the solution.
PhilSpo
December 3, 2019
Hey @Humberto Test user1
Is this 'Parent Link' the link between 'Initiatives' and 'Epics' as per the Portfolio add on?
Phil
Jamie Gerace November 11, 2020
Yeah Portfolio has since been changed to "advanced roadmaps for Jira" but the hierarchy is
Initiative
  • Epic (Epics are associated to Initiative through "Parent Link")
    • Tasks (Tasks associated to Epics through "Epic Link")
      • Sub-tasks
