×Hey,
I'm trying to make a simple rule in Automation for Jira which clone an issue in the same project but another issue type and i always get the same error:
Clone issue
Unexpected error executing rule:java.lang.NoClassDefFoundError: com/codebarrel/automation/api/thirdparty/AutomationRuleComponent
If i'm trying to create and not to clone issue, the same error i get.
Basically my rule is:
When: Value changes for
MyFieldName
If: MyFieldName contains any of
Option1, Option2, Option3
Then: Clone issue into
Same project
And: Link issue to
Trigger issue
Can somebody help me? Thanks.
Hi @Albert Manuel ,
this might be because your last action (Link Issue) is actually on the source issue, and is then in a loop trying to link to itself.
You should instead do a Link Issue to "Last created issue".
Let me know if this helps,
--Alexis
I have deleted that step entirely and i still get the same error.
I have updated the app to the last version. I have enable/disable the addon - nothing works...i just get that error.
The rule is simple now:
MyFieldName
Same project
Hi @Albert Manuel ,
did you make sure that the user running the rule can create issues in this project ?
Otherwise, it would be a good idea to open a support ticket to Atlassian : http://getsupport.atlassian.com/
--Alexis
