×hi,
I’m trying to create automation for copy custom field ("Project type") value from Initiative into Epic. Tried several solution from different posts but nothing works.
Issue are connected via: "relates to"
Below is the Rule screenshot
Shame on me and someone who before me create several Issue types called "Initiative", now, when I choose proper one it work... thx @Tansu Akdeniz and @Juan Carlos Vera for quick replays
Welcome to the community.
Could you find a trace in Audit Log section?
How did you set "Then: Edit Issue Fields" section?
Sample;
Hi @Jakub Hrynek ,
In the 'Automation' are you Copying the value of "Project Type" from Current issue ? Triggered issue? ... other?
I undestand that in your case you have to put Triggered issue.
