last successfully launched on September 30
help me fix it Best regards, Vyacheslav
Hi @Viacheslav Funtov -- Welcome to the Atlassian Community!
There is an active incident for scheduled trigger rules, which you may watch to monitor progress: https://jira-software.status.atlassian.com/incidents/50c77g3fb4y3
And also, I recommend checking the main status page regularly to learn if there incidents happening (or resolved) which could impact your site: https://status.atlassian.com/
Yes, thank you, I immediately checked that report. However, the automation item was marked as working.
After than I checked 4 hours ago (15:30 GMT +3:00) - automation already worked.
Thanks everyone for your sympathy!
Having same issues here too, cannot run rules manually too.
Hi @Viacheslav Funtov , welcome to the Atlassian Community and thanks for your question.
Please can you check the 'Usage' tab to see if there is any information or error message there? As you say, I don't see anything in the rules or audit log themselves.
Cheers
Hi @Viacheslav Funtov , thanks for the screen. I've escalated this to Atlassian to ask for help.
Keep watching this question for a reply.
Cheers
