×I am trying to set a fix version in automation for jira via the advanced editing of a field (because the field is not actually on the screen so i can't set it normally) and getting the below error
JSON:
"fields": {
"customfield_10800": "{{issue.customfield_10800.id}}",
"fixversions": [{"name": "{{fixversions.name}}"}]
actually i figured this out i had to create a variable as the fix version was not accessible inside of the branch
Can you try this
{{issue.fixVersions.name}}
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-issues/#--issue.fixVersions--
same issue
