Automation help
Abdelmoghny Mohamed May 19, 2022
hi , i have hundreds of tasks and subtasks assigned to a specific employee. how can i by automation to re assign those tasks to another specific person.
Callum Carlile _Automation Consultants_
Hi @Abdelmoghny Mohamed
You can either run the JQL of the assigned issues you want to reassign and then use the Bulk Edit functionality to change the assignee, or if you did want to use an automation rule (e.g. you may not have the global Make Bulk Changes permission) then you can just as easily do this in an automation rule, which would look something like the following:
(where you would run the JQL within the branch and change Unassigned to the user you wish to reassign them to in the Assign Issues action).
Hope this helps!
Danielle Green
Since they have all been already created, Bulk Edit is probably your best option:
https://community.atlassian.com/t5/Jira-questions/How-Do-I-Bulk-Change-an-Assignee-in-the-Backlog/qaq-p/1965543
