Automation options for subtask summaries
Jon
i just set up to use scriptrunner to automatically create subtasks based on a parent issue. the subtasks have a numberical number given from Jira and then they reference the parent issue summary. is it possible to change this? For example it has SS-193 / Summary from parent. could i do Summary field from parent -1 and so on?
Joshwa Marcalle
October 29, 2018
Hi Jon,
Scriptrunner is nice, but for automated subtasks it is a bit heavy, specially if you need to change the schemes frequently for many users.
Have you considered a specialised addon for managing automated subtasks? I would recommend you this one: https://marketplace.atlassian.com/apps/1218418/automatic-subtasks-professional?hosting=cloud&tab=overview
Hope this helps
Josh
Ob1
