Automation question
Sean Joo June 30, 2022
In Jira software (SCRUM) If I pulled a ticket to the backlog, is it possible for me to sync status? something like if I close a cloned task in SCRUM the ticket in the service management close automatically?
2 accepted
Alexander Bondarev
June 30, 2022
Hi, @Sean Joo !
Welcome to the Community!
Yes, you can. I recommend you to start with automation rules;
Thank you I will try
John Funk
Hi Sean - Welcome to the Atlassian Community!
You can certainly do that with an Automation for Jira rule.
Create a rule based on an Issue Transitioned trigger.
Then add any Conditions needed.
Then add a branch that identifies the linked issue.
Finally, add a new action for Transition issue.
I will try it thank you.
