Automation rule: How to check if previous assignee is in specific group
Gal Fatal
I try to build automation rule that tigered by assignee change,
I want to add a condition that checks if the former assignee belongs to a specific group.
I tried to use smart value  fieldChange.from to get the previous assignee id but now I want to check if this id is in specific group, cannot find easy way to do it
Any idea ? thanks , Gal.
Bill Sheboy
July 7, 2025
Hi @Gal Fatal
There are currently only two ways to do what you ask:
  • User Condition and a Custom Field
    • with the changelog entry, save the previous value in a single-select, user custom field
    • use a Re-fetch the Work Item Data action to reload the update
    • use a User Condition to test the custom field value is in your group
  • REST API
    • with the Send Web Request action, call the REST API endpoint to get the groups for the user, based upon the changelog
    • use smart values and conditional logic to test for your group
pawarsachin84
Hello @Gal Fatal ,
You can try to check below if this helps.
  • Add a custom user picker field (e.g., Previous Assignee)
  • On assignee change:
    • Set this field to {{changelog.assignee.from}}
  • Use the User is in group condition on that field (this is allowed)
  • Then proceed with your actions
Steps
1. Pre-requisite: Add Custom Field
  • Create a User Picker (single user) field named Previous Assignee
  • Add it to your issue screens
2. Automation Rule Setup
Trigger: Field Value Changed
Field to monitor: Assignee
Action: Edit Issue → Set “Previous Assignee”
Choose field: Previous Assignee
Set value using smart value:
Condition: User Condition
User field: Previous Assignee
Condition: “is in group”
Group name: Your desired group (e.g., engineering-team)
Action 2: [Your desired action, e.g., send message]
Bill Sheboy
July 7, 2025
Hi @pawarsachin84
What is the source of your information?
There is no "branch: lookup user" and the User Condition cannot access a smart value, such as from the changelog.
pawarsachin84
Hello @Bill Sheboy ,
Thank you for correcting me.
You're correct — there's no Branch: Lookup user or ability to check group membership directly on the changelog.assignee.from value.
However, in this case Gal Fatal can:
  1. Create a User Picker custom field (e.g., "Previous Assignee")
  2. Use changelog.assignee.from to populate it upon assignment change
  3. Add a User condition to check if that field’s user is in your target group
  4. add the necessary action to take on.
Bill Sheboy
July 7, 2025
Yes, that is what I suggested, and...it requires adding a Re-fetch Work Item Data after the edit so the condition gets the updated information.
Like # people like this
pawarsachin84
You're absolutely right — I agree with you.
