Automation rule issue
Pran mohan kumar
March 31, 2025
i am not project admin but i can create automation rule and when i create automation rule i  validated that rule then i turn on that rule when i turn on the rule then error occurs that there is some issue in your rule validate that and turn on but i already validate that and there is no error
Tansu Akdeniz
Hi @Pran mohan kumar
Welcome to the community.
Could you share the error? A screenshot?
Valerie Knapp
Hi @Pran mohan kumar , welcome to the Atlassian Community and thanks for your question.
Please can you post some anonymised screens of what is happening?
It could be that you can create rules but you don't have the permission in the project to effect the actions of the rule, for example, so you might need to have the rule run as another actor.
If you can show us some screens, we should be able to help you sort out the problem.
Best wishes
