×Hi
is it possible to set up an automation rule that changes the access level of a team managed projects to private? Trigger would be new team managed project created.
Joscha
Hi @Joscha , thanks for your question.
I don't see a way to do this in Automation, maybe it would be possible with a script.
I would suggest another way to approach this, if you don't want team-managed projects to be visible to everyone, would be to restrict who can create team-managed projects with the global permission -
If you have a smaller group of people who can create the projects, you can ask them to set them to private, rather than leaving open the possibility that everyone could create projects and having to change the access retrospectively.
Hope this helps but would be glad to hear your feedback on this idea / approach.
Cheers
