×Hello,
I'm trying to setup automation that:
1. Search a Jira project daily for any issues that have no labels
2. Take those issues and post the links into a Slack channel.
I've managed to get as far as the scheduled rule with the JQL to generate a list of issues that would be missing labels:
project = "ST" AND created >= -1d AND labels IS EMPTY
But I'm a bit clueless as to how to do the next step. Or have I gone about it in the wrong way?
Many thanks for any help.
Hi @Marije Pierson - You'll want something like this:
{{#lookupIssues}}
> <{{url}} | {{key}}> : {{summary}}
Yes, and...to Mark's answer...
Automation rules often require a bit of learning and experimentation. To help get you started on creating your rule, please review this documentation and examples:
