Automation to search for certain issues missing info > ping Slack daily
Marije Pierson
I'm trying to setup automation that:
1. Search a Jira project daily for any issues that have no labels
2. Take those issues and post the links into a Slack channel.
I've managed to get as far as the scheduled rule with the JQL to generate a list of issues that would be missing labels:
project = "ST" AND created >= -1d AND labels IS EMPTY
But I'm a bit clueless as to how to do the next step. Or have I gone about it in the wrong way?
Many thanks for any help.
Mark Segall
Hi @Marije Pierson - You'll want something like this:
  • TRIGGER: Scheduled Daily
    • Leave "Run a JQL search and execute actions for each issue in the query." Unchecked
  • ACTION: Lookup Issues
    • project = "ST" AND created >= -1d AND labels IS EMPTY
  • ACTION: Send Slack Message
    • {{#lookupIssues}}
      >  <{{url}} | {{key}}> :  {{summary}}
Bill Sheboy
February 28, 2023
Hi @Marije Pierson
Yes, and...to Mark's answer...
Automation rules often require a bit of learning and experimentation.  To help get you started on creating your rule, please review this documentation and examples:
Like # people like this
Marije Pierson
Thank you Mark, it worked perfectly :)
